All tools to create dimension entities can be found either on the Dimensions toolbar or in the Dimensions menu.
Toolbar |
Circles flyout
Menu |
Icon |
Tool name |
Command |
Creates horizontal or vertical linear dimensions. |
Creates linear dimensions which are aligned with the dimension points. |
Creates rotated linear dimensions. |
Creates angular dimensions |
Creates arc length dimensions |
Creates a leader with or without text. |
Draws center lines in circles and circular arcs. |
Creates diametrical dimensions in circles and circular arcs. |
Creates radial dimensions in circles and circular arcs. |
Creates stacked linear dimensions. |
Creates a chain of linear dimensions, starting from an existing linear dimension entity. |
Creates ordinate dimensions. |
Defines the layout of geometric tolerances. |
DIMEDIT + O |
Makes the extension lines of the selected dimension(s) oblique. |
DIMEDIT+ E |
Defines the dimension text of the selected dimension(s). |
DIMEDIT+ R |
Rotates the dimension text of the selected dimension(s). |
Lets you reposition the dimension text. |
Undoes the rotation or repositioning of the dimension text of the selected dimension(s). |
-DIMSTYLE + A |
Applies the current dimension style to the selected dimension(s). |
-DIMSTYLE + S |
Saves the current dimension settings in a new dimension style. |
Sets the current dimension style. |
-DIMSTYLE + ST |
Displays the status of the dimension variables in the command bar and the Prompt History window.. |
