Creates a cylinder as a polygon mesh (Classic); creates a cylinder as a 3D solid (Pro and Platinum).
command bar: cylinder
alias: cyl
menu bar: Model | 3D Solids | Cylinder
toolbar: 3D Solids | ![]()
: cylinder
Select center point or [3Point/2Point/Tangent-tangent-radius/Elliptical]: (Enter coordinates, pick a point, or choose an option.)
Radius of base of cylinder or Diameter <x.xx>: (Enter a distance or press Enter to accept the previously entered value, pick a point, or enter D.)
Specify height or [2Point/Axis endpoint] <x.xx>: (Enter a distance or press Enter to accept the previously entered value, pick a point, or choose an option.)
If Dynamic Dimensions are active, you can enter the dimensions in the dynamic dimensions entry fields.
Specifies the radius of the cylinder; prompts you: Diameter of base of cylinder <x.xx>: - enter coordinates, a distance, pick a point or press Enter to accept the previously entered value. |
Specifies the height of the cylinder as the distance between two points. Prompts you: Specify first point - enter coordinates or pick a point. Specify second point - enter coordinates or pick a point. |
Specifies the endpoint of the axis, allowing to create a cylinder of which the axis is not parallel to the Z-axis of the current coordinate system. Prompts you: Specify axis endpoint - enter coordinates or pick a point. |
Grips Editing
Cylinders can be edited directly through grips:
Select the cylinder. Notice that it has two grips.
Drag a grip to move the cylinder. (Both grips perform the same function: move.)
Pyramid - creates a pyramid as a 3D solid (Pro and Platinum). Creates a pyramid as a polygon mesh (Classic)
Region - creates 2D regions from 2D entities.
Sphere - creates 3D balls as solid models.
