ExternalReference object
Class AcadExternalReference
Member of BricscadDb
An instance of an external reference inserted into a drawing. To query or edit an existing external reference, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Document
Copy EffectiveName
Delete Handle
GetAttributes HasAttributes
GetBoundingBox HasExtensionDictionary
GetExtensionDictionary Hyperlinks
GetXData InsertionPoint
Highlight InsUnits
IntersectWith InsUnitsFactor
Mirror IsDynamicBlock
Mirror3D Linetype
Move LinetypeScale
Rotate Lineweight
Rotate3D Material *
ScaleEntity Name
SetXData Normal
TransformBy ObjectID
Update ObjectName
  OwnerID
  Path
  PlotStyleName
  Rotation
  TrueColor
  Visible
  XEffectiveScaleFactor
  XScaleFactor
  YEffectiveScaleFactor
  YScaleFactor
  ZEffectiveScaleFactor
  ZScaleFactor
