Region object
Class AcadCircle
Member of BricscadDb
To access the Region object, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Area
Boolean Centroid
Copy Document
Delete Handle
Explode HasExtensionDictionary
GetBoundingBox Layer
GetExtensionDictionary Linetype
GetXData LinetypeScale
Highlight Lineweight
IntersectWith Material
Mirror MomentOfInertia
Mirror3D Normal
Move ObjectID
Rotate ObjectName
Rotate3D OwnerID
ScaleEntity Perimeter
SetXData PlotStyleName
TransformBy PrincipalDirections
Update PrincipalMoments
  ProductOfInertia
  RadiiOfGiration
  TrueColor
  Visible
