Tolerance object
Class AcadTolerance
Member of BricscadDb
The Tolerance object represents geometric tolerance. To create tolerance, use the AddTolerance method. To modify or obtain information about a Tolerance object, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular DimensionLineColor
Copy DirectionVector
Delete Document
GetBoundingBox Handle
GetExtensionDictionary HasExtensionDictionary
GetXData Hyperlinks
Highlight InsertionPoint
IntersectWith Layer
Mirror Linetype
Mirror3D LinetypeScale
Move Lineweight
Rotate Normal
Rotate3D ObjectID
ScaleEntity ObjectName
SetXData OwnerID
TransformBy PlotStyleName
Update ScaleFactor
  StyleName
  TextColor
  TextHeight
  TextString
  TextStyle
  TrueColor
  Visible
