Class AcadXline
Member of BricscadDb
The InfiteLine object represents an line extending infinitely in both directions. To create an infinite line, use the AddInfiniteLine method. To access the Ellipse object, use the following methods and properties.
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | BasePoint |
Copy | Color |
Delete | DirectionVector |
GetBoundingBox | Document |
GetExtensionDictionary | Handle |
GetXData | HasExtensionDictionary |
Highlight | Hyperlinks |
IntersectWith | Layer |
Mirror | Linetype |
Mirror3D | LinetypeScale |
Move | Lineweight |
Offset | PlotStyleName |
Rotate | SecondPoint |
Rotate3D | TrueColor |
ScaleEntity | Visible |
SetXData | |
TransformBy | |
Update |
© Bricsys NV. All rights reserved. |
