Class AcadEllipse
Member of BricscadDb
The Ellipse object represents an elliptical arc or full ellipse. To create an ellipse use the AddEllipse method. To access the Ellipse object, use the following methods and properties.
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | Area |
Copy | Center |
Delete | Document |
GetBoundingBox | EndAngle |
GetExtensionDictionary | EndParameter |
GetXData | EndPoint |
Highlight | Handle |
IntersectWith | HasExtensionDictionary |
Mirror | Hyperlinks |
Mirror3D | Layer |
Move | Length |
Offset | Linetype |
Rotate | LinetypeScale |
Rotate3D | Lineweight |
ScaleEntity | MajorAxis |
SetXData | MajorRadius |
TransformBy | Material * |
Update | MinorAxis |
MinorRadius | |
Normal | |
ObjectID | |
ObjectName | |
OwnerID | |
PlotStyleName | |
RadiusRatio | |
StartAngle | |
StartParameter | |
StartPoint | |
TrueColor | |
Visible |
© Bricsys NV. All rights reserved. |
