Hatch object
Class AcadHatch
Member of BricscadDb
The Hatch object represents an area fill consisting of a pattern of lines. To create a hatch, first create the Hatch object using the AddHatch method. To query or edit an existing block reference, use the following methods and properties:
Methods Properties
AppendInnerLoop Application
AppendOuterLoop Area
ArrayPolar AssociativeHatch
ArrayRectangular Document
Copy Elevation
Delete GradientAngle
GetBoundingBox GradientCentered
GetExtensionDictionary GradientColor1
GetLoopAt GradientColor2
GetXData GradientName
Highlight Handle
InsertLoopAt HasExtensionDictionary
IntersectWith HatchObjectType
Mirror HatchStyle
Mirror3D Hyperlinks
Move ISOPenWidth
Rotate Layer
Rotate3D Linetype
ScaleEntity LinetypeScale
SetPattern Lineweight
SetXData Material
TransformBy Normal
Update NumberOfLoops
  ObjectID
  ObjectName
  OwnerID
  PatternAngle
  PatternDouble
  PatternName
  PatternScale
  PatternSpace
  PatternType
  TrueColor
  Visible
