Create a button with or without a label. DCL Active Tile
This active tile creates a button, with or without a superimposed label. A button is generally used to exit a dialog box or to display another box ("tunneling dialog boxes"). Every dialog box must have at least one button, which is connected to the LISP function done_dialog; otherwise the program hangs.
NOTE Several predefined tiles provide the most common button clusters, including the ok_only attribute, ok_cancel, and ok_cancel_help tiles.
Valid Attributes
Example
NOTE The label attribute indicates the text on the button-for example:
label = "Sync Grid to Snap"
Related DCL Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
