Display a check box. DCL Active Tile
This active tile displays a check box. When turned on, the check box contains a check mark and the value attribute returns 1. The text for the associated label attribute appears to the right of the box.
Valid Attributes
Example
NOTE The value attribute indicates whether the check box is currently selected (indicated by a check mark), via the value of "1":
value = "1"
Related DCL Tiles
Tell me about...
Programming Overview of DCL (Dialog Control Language)
