: edit_box
Let the user type a line of
text. DCL Active Tile
This active tile displays an edit box tile that prompts the user
to type a number or text. Text in the edit box is left-justified.
The program appends the null character (\0) to the end of the
string the user types. If an edit_limit is specified, and the specified
character count is reached, all user entry other than backspace and
delete are ignored.
Valid Attributes
: edit_box {
action
= "(string)";
alignment
= position;
allow_accept
= flag;
edit_limit
= int;
edit_width
= number;
fixed_height
= flag;
fixed_width
= flag;
height
= number;
is_enabled
= flag;
is_tab_stop
= flag;
key
= "string";
label
= "string";
lower_only
= flag;
mnemonic
= "char";
password_char
= "char";
read_only
= flag;
upper_only
= flag;
value
= "string";
width
= number;
Example
: edit_box {
action
= "(texted)";
allow_accept
= true;
edit_limit
= 31;
key
= "EB";
label
= "File name: ";
mnemonic
= "F";
value
= "drawing";
NOTE
- The label
attribute defines the edit box's title; it is left-justified.
- The value
attribute holds the initial text displayed by the edit box; it is
left-justified.
- The following attributes are unique to the
implementation of DCL included with Bricscad: lower_only, read_only, and upper_only.
Related DCL Tiles
button
image_button
list_box
popup_list
radio_button
slider
toggle
Tell me about...
Programming
Overview of DCL (Dialog Control Language)
About
Predefined Attributes
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
