: multi_edit_box
Display an edit box with more than one
line. DCL Active Tile
This active tile displays a multiline edit box tile, which
allows the user to type additional lines of text. Text in the
multi_edit_box
tile is left-justified. The program appends the null character (\0)
to the end of the string.
The multi_edit_box tile is unique to the
implementation of DCL included with Bricscad.
Valid Attributes
: multi_edit_box {
action
= "(string)";
alignment
= position;
allow_accept
= flag;
edit_limit
= int;
edit_width
= number;
fixed_height
= flag;
fixed_width
= flag;
height
= number;
is_enabled
= flag;
is_tab_stop
= flag;
key
= "string";
label
= "string";
lower_only
= flag;
mnemonic
= "char";
password_char
= "char";
read_only
= flag;
upper_only
= flag;
value
= "string";
width
= number;
Example
: multi_edit_box {
action
= "(texted)";
edit_limit
= 40;
key
= "EB";
label
= "Type text: ";
mnemonic
= "T";
NOTE
- The label
attribute is the multiline edit box's title; it is
left-justified.
- The value
attribute holds the initial text displayed by the multiline edit
box; is left-justified.
- The following attributes are unique to the
implementation of DCL included with Bricscad: lower_only, read_only, and upper_only.
Related DCL Tiles
button
image_button
list_box
popup_list
radio_button
slider
toggle
Tell me about...
Programming
Overview of DCL (Dialog Control Language)
About
Predefined Attributes
Bricscad™ is commercialized by Bricsys NV. Bricsys NV and Vondle NV
are fully owned subsidiaries of Menhirs NV. © 2001- Menhirs NV - All rights reserved. |
