Works with Bricscad (Windows) Platinum
Creates a three-dimensional X-Solid box.
command bar: xbox
menu bar: X-Solids| Box
toolbar: X-Solids| ![]()
: xbox
Specifies the x,y,z coordinates of the origin point:
Width Y Height Z |
Specify the dimensions of the box: Length X: parallel to the X-axis of the current UCS Width Y: parallel to the Y-axis of the current UCS Height: parallel to the Z-axis of the current UCS
Disables the Width Y and Height Z fields. Creates a box with equal sides using the Length X field. |
The Create X-Solid Box dialog box temporarily closes. Prompts you in the command bar: Base/ceNter/<Corner of box> <0,0,0>: Specify the dimensions of the box in the drawing.
Displays a preview of the box in the drawing in dashed lines. |
The Create X-Solid Box dialog box temporarily closes. Displays the View Options dialog box:
The Create X-Solid Box dialog box closes. Displays the Manipulate dialog box to Move, Rotate or Align the X-Solid Box.
Move: Prompts you in the command bar to specify the displacement vector by clicking two points. Move To: Prompts you in the command bar to move the origin point of the X-Solid box. Rotate: Type an angle in the Angle field or choose an angle in the list box, then click an axis button to rotate the X-Solid box. Align: Aligns the X, Y or Z-axis of the X-Solid box. Prompts you in the command bar to specify two points. The X-Solid box is rotated about its origin. Done: Creates the X-Solid box. OK: Reopens the Create X-Solid Box dialog box. Cancel: Aborts the XBox command. |
Creates the X-Solid box. |
Launches the XUnion, XIntersect or XSubtract command to be executed using the newly created X-Solid box. You are prompted in the command bar to select one or more other solids. |
Grips Editing
X-Boxes can be edited directly through grips:
Select the box. Notice that it has many grips.
Drag any grip to move the box. (All eight grips perform the same function: move.)
Box - creates 3D boxes as Acis solid models.
Wedge - creates a wedge as a polyface mesh (Classic); creates a wedge as a 3D solid (Pro and Platinum).
XCone - creates a cone as a 3D X-solid.
XCylinder - creates a cylinder as a 3D X-Solid.
XExtrude - extrudes 2D entities to X-solids.
XRevolve - revolves 2D closed entities to turn them into 3D X-Solids.
XSphere - Creates a sphere as a 3D X-Solid.
XSweep - Extrudes 2D entities along a path to X-solids.
XTorus - creates a torus as a 3D X-Solid.
XWedge - creates a wedge as a 3D X-Solid.
