The following keyboard shortcuts are available:
Keyboard |
F1 |
Opens the BricsCAD Help. |
F2 |
Toggles the display of the Prompt History window. |
F3 |
Toggles Entity Snaps. |
F4 |
Toggles the tablet mode. |
F5 |
Sets the isoplane (see Using Isometric snap). |
F6 |
Toggles the Dynamic UCS feature. |
F7 |
Toggles the display of the grid. |
F8 |
Toggles the Ortho setting. Disables Polar Tracking, if on. |
F9 |
Toggles the Snap setting. |
F10 |
Toggles the Polar Tracking setting. Disables Ortho, if on. |
F11 |
Toggles the Entity Snap Tracking setting. |
F12 |
Toggles the Quad display. |
Alt+F8 |
Launches the VBARUN command. |
Alt+F11 |
Launches the VBAIDE command. |
Ctrl+1 (*) |
Toggles the properties bar. |
Ctrl+2 (*) |
Opens the Drawing Explorer. |
Ctrl+9 (*) |
Toggles the display of the command bar. |
Ctrl+A |
Selects entities. |
Ctrl+B |
Ctrl+C |
Copies the selection to the clipboard (COPYCLIP command). |
Ctrl+Shift+C |
Copies the selection along with a base point (COPYBASE command). |
Ctrl+E |
Ctrl+F |
Toggles entity snaps on/off. |
Ctrl+G |
Ctrl+H |
Toggles the value of the PICKSTYLE system variable, which controls the selection of groups and associative hatches. |
Ctrl+I |
Sets the readout of the coordinate field in the status bar. |
Ctrl+J |
Repeats the previously issued command. |
Ctrl+K |
Attach a hyperlink to an object or modify an existing hyperlink (HYPERLINK command). |
Ctrl+L |
Toggles the Ortho setting. |
Ctrl+M |
Ctrl+N |
Creates a new drawing (NEW command). |
Ctrl+O |
Opens an existing drawing (OPEN command). |
Ctrl+P |
Prints the current drawing (PRINT command). |
Ctrl+Shift+P |
Ctrl+Q |
Quits the application; prompts to save changes (QUIT command). |
Ctrl+R |
Iterates through viewports. |
Ctrl+S |
Saves the current drawing (QSAVE command). |
Ctrl+T |
Turns the tablet on/off. |
Ctrl+V |
Pastes the contents of the Clipboard into the drawing (PASTECLIP command). |
Ctrl+Alt+V |
Pastes the contents of the Clipboard in a specified format (PASTESPEC command). |
Ctrl+Shift+V |
Pastes the contents of the Clipboard as a block (PASTEBLOCK command). |
Ctrl+X |
Cuts the selection and puts it on the clipboard (CUTCLIP command). |
Ctrl+Y |
Redoes the last action undone (REDO command). |
Ctrl+Z |
Undoes the last action (UNDO command). |
Ctrl+[ |
Cancels the running command. |
Ctrl+\ |
Shift+F2 |
Shift+F3 |
Turns the Status Bar on/off (STATBAR command). |
Shift+F4 |
Turns the Scroll Bars on/off (SCROLLBAR command). |
Shift+F8 |
Launches the Visual Basic Project Manager (VBAMAN command). |
Shift+F11 |
Launches the VBA COM Add-In Manager (ADDINMAN command). |
PgUp |
Moves the view up. |
PgDn |
Moves the view down. |
Shift+Left Arrow |
Moves the view to the left. |
Shift+Right Arrow |
Moves the view to the right. |
Shift+Up Arrow |
Shift+Down Arrow |
(*) Do not press the Shift key on AZERTY-keyboards.
