Drawing Explorer
Tips and Tricks for Drawing Explorer
Commands: EXPLORER, LAYER, LAYERSTATE, LINETYPE, MLSTYLE, MLEADERSTYLE, STYLE, DIMSTYLE, TABLESTYLE, EXPUCS, VIEW, VISUALSTYLES, LIGHTLIST, MATERIALS, RENDERPRESETS, EXPBLOCKS, XREF, IMAGE, PDF, eTRANSMIT, PAGESETUP, SECTIONPLANESETTINGS
The Drawing Explorer
The Drawing Explorer window consists a number of sub-windows or panes:
You can select which panes you want to have open or closed in the View menu.
BricsCAD remembers the display settings for each category.
To open the Drawing Explorer
To open the Drawing Explorer window do one of the following:
To control the Drawing Explorer layout
Opening a drawing
To open a drawing using the Drawing Explorer do the following
  1. Launch the Drawing Explorer.
  2. In the Drawings > Folders  sub-window browse to the folder of the drawing.
  1. Double click the drawing.
    The drawing opens, while the Drawing Explorer window stays open.
  2. (optional) Repeat steps 2 and 3 to open more drawings.
  3. Close the Drawing Explorer.
NOTE
When you select a drawing, a preview displays in the Preview  sub-window.
Adding a drawing folder
  1. In the Drawings > Folders  sub-window of the Drawing Explorer main window click the  Add local folder... button.
    The Browse For Folder window opens.
  2. In the Browse For Folder window do one of the following:
  1. Click the OK button.
    The folder is added.
NOTE
  • Drawings in the subfolders of the selected folder can be opened too.
  • The parent folder(s) of the selected folder is (are) greyed out in the drawing folder tree. Drawings in such folders cannot be opened.
To insert a block from an unopened drawing
The Block Manager feature of the Drawing Explorer allows to insert blocks in the current drawing  from unopened drawings.
To copy definitions between drawings
  1. Open both the source and the target drawing.
  2. Launch the Drawing Explorer.
  3. In the source drawing select the category you want to copy items from, e.g. Blocks.
  4. (option) In the Details toolbar, click the Icon View button ()
  5. Select the item(s) you want to copy, e.g. a series of blocks.
    Press and hold the Ctrl key to select multiple items.
  6. Press and hold the left mouse button to drag the selection set to the Open Drawings section of the Drawing Explorer.
  7. Release the left mouse button when on the target drawing name.
    The selected items are copied to the target drawing.
    You will be prompted to overwrite items of the same name.
To merge the content of two layers
  1. Open the Drawing Explorer > Layers dialog window.
  2. Select the layer you want to merge into another layer.
  3. Choose Merge to... in the Edit menu.
    The Merge Layers dialog box displays.
  4. Select the layer you want to merge to.
  5. Click the Merge button.
    The content of the first layer is merged to the second layer.
    The first layer is purged from the drawing.
