Box
Creates a box as a polyface mesh in Classic and Linux; Creates box as a 3D solid  in Pro.
command bar:  box
menu bar:  Draw | 3D Entities | Box
toolbar:   Solids |
: box
Center/<Corner of box> <0.0000,0.0000,0.0000>: (Pick a point, or enter an option.)
Cube/Length/<Opposite corner>: (Pick another point, or enter an option.)
Height of box: (Pick two points, or enter a height.)
Corner of box
Specifies one corner of the box's base.
Enter x,y,z coordinates or pick a point in the drawing.
Center
Specifies the center of the box's base.
Cube
Specifies a box with equal sides:
Length of sides of cube - enter a length, or pick two points.
Length
Specifies the lengths of each side:
Length of side of box - specify the length in the x direction.
Width of box - specify the length in the y direction.
Height of box - specify the length in the z direction.
You may enter negative values to draw the box in the downward directions.
Opposite corner
Specifies the opposite corner of the box's base.
Height of box
Specifies the height of the box.
Enter a length or pick two points in the drawing.
Grips Editing
Boxes can be edited directly through grips:
  1. Select the box. Notice that it has many grips.
  2. Drag any grip to move the box. (All eight grips perform the same function: move.)
Sphere -  creates 3D balls as solid models.
