Sphere
Works with Classic, Pro
Creates a sphere as a 3D mesh surface in Classic and Linux; Creates a 3D solid sphere in Pro.
command bar:  sphere
menu bar:  Draw | 3D Entities | Sphere
toolbar:   Solids |
: sphere
Center of sphere: (Pick a point, or enter coordinates.)
Diameter/<Radius of sphere>: (Specify a distance, or type D.)
Center of sphere
Specifies the center point of the sphere; enter x,y- or x,y,z-coordinates, or pick a point in the drawing.
Radius of sphere
Specifies the radius.
Diameter
Specifies the diameter.
Grips Editing
Spheres can be edited directly through grips:
  1. Select the sphere. Notice that it has one grip.
  2. Drag the grip to move the sphere.
Sphere -  creates 3D balls as solid models.
