What's New in Bricscad V12
Below is a brief description of the enhancements and new features. Click on the hyperlink keywords for a detailed description.
Some features or commands might not be available yet on the Linux platform. Please check the Command Reference guide.
MENUS and TOOLBARS have been extended and reorganized.
Click here to read the Bricscad Release Notes (Internet connection needed).
New items in V12.2
PUBLISH command: Allows to print a sheet list (= a list of model space or paper space layouts) to a printer. Saves a sheet list to a file.
PUBLISHALLSHEETS system variable: Specifies whether to load the contents of the active document or of all open documents in the Publish dialog box.
LAYER FILTERS: use expressions and layer properties to filter out sets of layers, and store filters for reuse. The option to hide or show XREF layers has been removed. The layer toolbar listens to the current layerfilter.
SHOWLAYERUSAGE system variable: shows layer information in the Drawing Explorer - Layers dialog box.
LAYER EXPLORER: for layouts and paper space viewports, columns were added for ViewPort (VP) Color, VP Linetype, VP Lineweight and VP Plot Style.
XOPEN command: Opens an external reference. The command is available from XREF context menu and from the Drawing Explorer - External References dialog box.
DRAWING EXPLORER - DRAWINGS: Possibility to browse and insert blocks from unopened drawings into the current drawing. Drawings in the Folders tab are available.
EXPBLOCKS: Added Description column (block comments) to blocks detail view.
LOOK FROM toolbar: TopBottom flyout is added to the middle button of the Look From toolbar. The first button is the same as before, i.e. rotate the view to top view, the second button rotates the view to the bottom view.
PRINT: A Print To File checkbox is added to the Print dialog.
TABLEEXPORT: The Export Table option is added to the context menu when one table entity is selected.
TOOLPALETTES: On a tool palette you can add blocks, hatches and commands in a tabbed window.
DMRIGIDSET3D: Allows to define a set of entities or subentities as a rigid body.
New items in V12.1
LAYOUT TABS:
FILE DIALOG: All 5 icons in the Places bar at the left of the dialog are now customizable in the SETTINGS dialog (Program Options > Files > File Dialogs > Places bar), 4 of them can be chosen from a combo with predefined options, the fifth is still initialized from DRAWINGPATH setting as before.
DRAWING EXPLORER > LAYERS: Merge To ... option in the Edit menu to merge the content of two layers.
2D-CONSTRAINED drawing:
3D Modeling option in the New Drawing Wizard procedure and related 3D template drawings.
3D-CONSTRAINED drawing
DIRECT MODELING
Enhanced 3D modeling features in Bricscad V12, are enabled or disabled by a set of preferences and system variables, both existing and new ones. All these settings are editable in the Settings dialog, either by browsing to them, or typing a part of their name in the search field on top of the dialog. Below are recommended values for these settings. These are the default values, but if you experience problems when working in 3D, you might want to check their value.
DRAWORDER commands:
HATCH
PAGE SETUP
PDF UNDERLAY
SHORTCUTS
VISUAL STYLES:
SECTIONS
RASTER ENGINE: New Imagine multi-resolution raster engine, designed to swiftly handle large images.
MODELERPROPERTIES and -MODELERPROPERTIES commands to control various settings of the Acis modeler. FACETRES is now used for display by default.
QTEXT: toggles between normal text display and simplified text display (as rectangles).
SCALELISTEDIT command allows to extend the scale lists used in Print dialog and Viewport properties.
TEIGHA 3.5 UPDATE: invisible at the surface, important code modifications took place: we upgraded the underlying ODA DwgDirect V2.06 libraries to ODA Teigha V3.05, bringing along hundreds of fixes.
ADT: object enabler for Autocad Architectural Desktop.
SYSTEM VARIABLES:
All user preferences now can be modified from the command line (like system variables).
Menus and toolbars
In V12 menu items and toolbar buttons are reorganized, a few menus and toolbars are added.
See the User Guide / User Interface / Toolbars for a list of all Bricscad V12 toolbars.
The following menus are new:
Model menu: All 3D related commands are grouped in this new menu:
Parametric menu: this new menu contains all 2D and 3D constraints commands.
The following menus are modified:
File menu:
View menu: new 2D Context and 3D Context items are added.
Insert menu: the items are reorganized and the Layout flyout is removed. The Hyperlink item is added.
Settings menu: the Drawing Explorer categories have been moved and grouped as a flyout of  the Tools menu.
Tools menu:
Draw menu:
Dimensions menu: the order and grouping of the items has changed.
Modify menu:
The following menus have been removed:
Images menu: Insert Image sits in the Insert menu, image editing tools are moved to the Raster Image flyout of the Modify menu. Image management can be found in the Tools / Drawing Explorer menu.
X-Solids menu: X-Solids items are moved to the X-Solids (History Based) item in the new Model menu.
