DimAligned
Draws dimensions parallel to (aligned with) selected entities; works with lines, polylines, arcs, and circles.
command bar:  dimaligned
alias:  dal, dimali
menu bar:  Dimension | Aligned
toolbar:  Dimensions |
: dimaligned
ENTER to select entity/<Origin of first extension line>: (Press Enter to dimension an entity.)
Select entity to dimension: (Select a line, polyline, arc, or circle.)
Angle/Text/<Location of dimension line>: (Pick a point to locate the dimension line away from the entity.)
Dimension text = \A1;3.7504
: dimaligned
ENTER to select entity/<Origin of first extension line>: (Choose a point to locate the first extension line.)
Origin of second extension line: (Choose a second point to locate the second extension line.)
Angle/Text/<Location of dimension line>: (Pick a point to locate the dimension line.)
Dimension text = \A1;1.3535
Press Enter to dimension a single entity.
Specifies the line, polyline, arc, or circle to dimension; other entities cannot be dimensioned with this option.
Location of Dimension Line
Locates the dimension line away from the entity; determines the length of the extension lines.
Angle
Specifies the angle of the text; useful for keeping text horizontal with inclined dimension lines.
Text
Specifies the text; useful for overriding the default measurement generated by BricsCAD.
Origin of First Extension Line
Specifies the origin of the first extension line.
Origin of Second Extension Line
Specifies the origin of the second extension line.
Procedures
To create an aligned linear dimension
To create a horizontal or vertical linear dimension
To create a rotated linear dimension
Grips Editing
Aligned dimensions can be edited directly through grips:
  1. Select the aligned dimension. Notice the grips.
  2. Drag the grips to perform the following actions:
Move the dimension line by dragging either grip near the arrowhead:
Relocate the text and dimension line by dragging the grip centered on the dimension line (the leader is added automatically, if required):
Rotate and stretch the dimension by dragging either grip located at the base of the extension lines:
