DimTEdit
Changes the position of dimension text.
command bar:  dimtedit
alias:  dimted
menu bar:  Dimension | Reposition Dimension Text
toolbar:  Dimensions |
: dimtedit
Select dimension to reposition text: (Choose a dimension.)
Specify or enter text location: REstore/Angle/Left/Center/Right: (Drag the text to its new location, or enter an option.)
Select Dimension to Reposition Text
Chooses the dimension to edit.
REstore ()
Resets the rotation angle to 0 degrees; does not change repositioned text.
Angle ()
Rotates the dimension text. Prompts you:
Angle of dimension text - specify the angle of the text; measured counter-clockwise from the positive x axis.
Left
Moves the text next to the left extension line.
Center
Centers the text between the two extension lines.
Right
Procedures
Editing the dimension text
To rotate the dimension text
To reposition the dimension text
To restore the text position
