DimLinear
Places linear dimensions horizontally, vertically, or rotated.
command bar:  dimlinear
aliases:  dimlin, dli, dimhorizontal, dimrotated, dimvertical
menu bar:  Dimension | Linear
toolbar:  Dimensions |
: dimlinear
ENTER to select entity/<Origin of first extension line>: (Press Enter to dimension an entity.)
Select entity to dimension: (Choose a line, polyline, arc, or circle.)
Angle/Text/Horizontal/Vertical/Rotated: (Position the dimension line, or enter an option.)
Dimension text = \A1;4.0263
ENTER to select entity/<Origin of first extension line>: (Choose a starting point.)
Origin of second extension line: (Choose an ending point.)
Dimension text = \A1;6.6588
Press Enter to dimension a single entity.
Specifies the line, polyline, arc, or circle to dimension; other entities cannot be dimensioned with this option.
Location of Dimension Line
Locates the dimension line away from the entity; determines the length of the extension lines.
Angle
Specifies the angle of the text; useful for keeping text horizontal with inclined dimension lines. Prompts you:
Angle of dimension text - specify the rotation angle of the text.
Text
Specifies the text; useful for overriding the default measurement generated by BricsCAD. Prompts you:
Dimension text - specifies the replacement text.
Horizontal
Forces the dimension to be horizontal; prompts you 'Angle/Text/<Location of dimension line>:'.
Vertical
Forces the dimension to be vertical; prompts you 'Angle/Text/<Location of dimension line>:'.
Rotated
Rotates the dimension by a specified angle; prompts you:
Angle of dimension line - specify the angle of the dimension line.
Origin of First Extension Line
Specifies the origin of the first extension line.
Origin of Second Extension Line
Specifies the origin of the second extension line.
Procedures
To create a horizontal or vertical linear dimension
To create an aligned linear dimension
To create a rotated linear dimension
Grips Editing
Linear dimensions can be edited directly through grips:
  1. Select the linear dimension. Notice the grips.
  2. Drag the grips to perform the following actions:
