DimRadius
Dimensions the radii of arcs and circles.
command bar:  dimradius
alias:  dimrad, dra
menu bar:  Dimension | Radius
toolbar:  Dimensions |
: dimradius
Select arc or circle to dimension: (Choose an arc, polyline arc, or circle.)
Dimension text = \A1;%%c2.5806
Angle/Text/<Location of dimension line>: (Position the dimension, or enter an option.)
A circle with radius dimension placed outside
An arc with radius dimension placed inside
Select Arc or Circle to Dimension
Chooses the arc, polyline arc, or circle to dimension.
Location of Dimension Line
Locates the dimension leader line and text; drag the dimension around the entity, and inside or outside the entity.
Angle
Changes the angle of the text.
Text
Changes the default text generated by BricsCAD.
Procedures
To create a radial dimension
Creating center marks or center lines
To create a diametrical dimension
Grips Editing
Radial dimensions can be edited directly through grips:
  1. Select the radius dimension. Notice the grips.
  2. Drag the grips to perform the following actions:
