DimBaseline
Places multiple linear and angular dimensions starting at the same base point; this command can only be used when at least one other dimension is already in the drawing.
command bar:  dimbaseline
aliases:  dba, dimbase
menu bar:  Dimension | Baseline
toolbar:  Dimensions |
: dimbaseline
Baseline:  ENTER to select starting dimension/<Origin of next extension line>: (Pick a point to locate the second extension line.)
Dimension text = \A1;2.5472
Baseline:  ENTER to select starting dimension/<Origin of next extension line>: (Pick another point, or press Esc to exit the command.)
Baseline dimensions applied to a linear dimension
Baseline dimensions applies to an angular dimension
ENTER to Select Starting Dimension
Chooses the linear or angular dimension from which to continue dimensioning.
Origin of Next Extension Line
Locates the endpoint of the second extension line; the first extension line is co-located with the first extension of the starting dimension.
The command repeats this prompt until you press Esc.
Procedures
To create baseline dimensions
Grips Editing
Baseline dimensions can be edited directly through grips:
  1. Select the baseline dimension. Notice the grips.
  2. Drag the grips to perform the following actions:
