DimContinue
Continues linear and angular dimensions from the endpoint of the previous dimension.
command bar:  dimcontinue
aliases:  dco, dimcont
menu bar:  Dimension | Continue
toolbar:  Dimensions |
: dimcontinue
Continue: ENTER to select starting dimension/<Origin or next extension line>: (Choose a point for the endpoint of the second extension line.)
Dimension text = \A1;1.1135
Continue: ENTER to select starting dimension/<Origin or next extension line>: (Choose another point, or press Enter to exit command.)
Continue dimensions applied to a linear dimension
Continue dimensions applies to an angular dimension
ENTER to Select Starting Dimension
Chooses the linear or angular dimension from which to continue dimensioning.
Origin of Next Extension Line
Locates the endpoint of the second extension line; the first extension line is co-located with the second extension of the previous dimension.
The command repeats this prompt until you press Esc.
Procedures
To create continued dimensions
Grips Editing
Continued dimensions can be edited directly through grips:
  1. Select the continued dimension. Notice the grips.
  2. Drag the grips to perform the following actions:
