DimDiameter
Dimensions the diameter of circles and arcs, and places the center mark.
command bar:  dimdiameter
aliases:  ddi, dimdia
menu bar:  Dimension | Diameter
toolbar:  Dimensions |
: dimdiameter
Select arc or circle to dimension: (Choose an arc, polyline arc, or circle.)
Dimension text = \A1;%%c2.5806
Angle/Text/<Location of dimension line>: (Position the dimension, or enter an option.)
A circle with diameter dimension placed outside
An arc with diameter dimension placed inside
Select Arc or Circle to Dimension
Chooses the arc, polyline arc, or circle to dimension.
Location of Dimension Line
Locates the dimension leader line and text; drag the dimension around the entity, and inside or outside the entity.
Angle
Changes the angle of the text.
Text
Changes the default text generated by BricsCAD.
Procedures
To create a diametrical dimension
Creating center marks or center lines
To create a radial dimension
Grips Editing
Diameter dimensions can be edited directly through grips:
  1. Select the diameter dimension. Notice the grips.
  2. Drag the grips to perform the following actions:
