Class AcadRasterImage
Member of BricscadDb
The Image object represents a raster image consisting of a rectangular grid of small squares or dots known as pixels. To create a raster image use the AddImage method. To edit or query a raster image, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | Color |
Copy | Document |
Delete | EntityName |
Erase | |
GetBoundingBox | Handle |
GetExtensionDictionary | HasExtensionDictionary |
GetXData | Height |
Highlight | Hyperlinks |
IntersectWith | ImageFile |
Mirror | ImageHeight |
Mirror3D | ImageVisibility |
Move | ImageWidth |
Rotate | Layer |
Rotate3D | Linetype |
ScaleEntity | LinetypeScale |
SetXData | Lineweight |
TransformBy | Origin |
Update | Parent |
PlotStyleName | |
Visible | |
Width |
© Bricsys NV. All rights reserved. |
