What's New in BricsCAD V14
Below is a brief description of the enhancements and new features. Click on the hyperlink keywords for a detailed description.
Please read the BricsCAD Release Notes with the latest changes (new features, improvements and bug fixes and development features).
Important notes
BricsCAD® (Windows) V14 installs and runs independently from previous BricsCAD versions.
V14 is not binary compatible with V13, some API's have changed. Most 3rd party applications/tools, except scripts and applications written in pure Lisp, will need to be rebuilt by their manufacturer in order to run on V14. If you are using 3rd party applications, please check with your supplier for V14 compatibility and updates.
In trial mode, BricsCAD runs as full Platinum version without any feature restrictions.
The RunAsLevel user preference allows to run BricsCAD in a lower level than the licensed level. A restart is needed after changing this RunAsLevel user preference.
To report problems, please send a Support Request.
X-SOLIDS removed: new functionality has been added to the Mechanical tools to replace functionality offered by the X-solids tools. The history based X-solids modeling is retired.
LICENSING: BricsCAD V14 comes with a new licensing system.
New features overview
GUI:
UPGRADES:
New in 14.2
ANNOTATION SCALES: added the ability to view and edit the CANNOSCALE system variable in the Status Bar. The Custom option launches the SCALELISTEDIT command.
BricsCAD now supports CUIX files, which will be converted to CUI on-the-fly. When a CUIX file contains bitmaps, they are copied into a .RESZ resource file.
CUSTOMIZE: support for .RESZ files: an alternative to resource DLL (zip file containing tool bitmaps; works on all platforms).
GENERATED DRAWING VIEWS:
OVERKILL and -OVERKILL: Commands to remove duplicate entities, overlapping lines, circular arcs and polylines (lw, 2d, 3d), and also to combine partially overlapping or contiguous entities.
PARAMETERCOPYMODE:  System variable to control copying of 2D constraints and related parameters when entities are copied.
PREVIEWTOPDOWN toggle: when Shift + Ctrl keys are pressed simultaneously and not held down longer than 500 milliseconds, they toggle the PREVIEWTOPDOWN setting. In other words: selectionpreview highlight priority will be toggled between selecting individual faces of 3D solids first or selecting the entire 3d-solids first.
PUBLISH: added the possibility to use PDF export when publishing. Plot and Page Setup settings are applied. Using the "Multi-Sheet File" option allows to create a single pdf file containing multiple layouts from a single drawing. Multiple layouts from multiple drawings are not yet supported.
SELECT: added the G option which allows to select groups by name when selecting entities.
SHEET METAL:
SNAP TRACK:
HATCH PATTERN SNAP: added support for snapping to hatch pattern geometry, controlled by new OSOPTIONS system variable. The default value of OSOPTIONS is 3.
VISUALSTYLES: implemented the -VISUALSTYLES command.
New in 14.1
3D CONNEXION MOUSE: added 3D connexion mouse support. The 3D mouse is used for navigating the view while the regular mouse is used for controlling the pointer.
3D CONSTRAINTS: expressions and parameters can be used to specify the value of a dimensional constraint.
ADDSELECTED command creates a new entity based on the type of a selected entity, adopting general properties of the selected entity such as layer and color.
ANNOTATIVE STYLES and ENTITIES:
Added support for annotative styles and annotative entities. Annotative entities can be displayed in different ways (scale, location, rotation) depending on the viewport in which they are displayed. When hovering over annotative entities while selectionpreview is activated, the annotative marker will be displayed.
Entity types that obey annotative scaling include:
Related commands, variables and extensions:
CONVERTPOLY: command to convert lightweight polylines to classic polylines and vice versa.
DIMENSIONS: in-place editing of dimension text.
CPAGESETUP: command to edit the model space or the current layout page setup in the Page Setup dialog box. The command can be accessed by right clicking the model tab or the current layout tab and choosing Page Setup... in the context menu.
DRAG-AND-DROP OPTION MENU: when using the Right Mouse Button to drag and drop files onto the BricsCAD application, following options are offered from a context menu:
GENERATIVE DRAFTING:
HARDWARE LIBRARY: the new Library tab in the Mechanical Browser provides easy access to more than 30,000 three dimensional standard parts which can be drag-and-dropped into the drawing. Status: work in progress - Preview creation process to be improved, Length setting not yet functional.
HATCHEDIT command - allows to add or remove boundary entities to/from hatches.
HELIX command: Available geometrical helix properties are: Position(X/Y/Z), Constrain, Height, Turns, Turn Height, Base Radius, Top Radius, Twist, Turn Slope and Total length. Turn Slope and Total length are not editable. The Base Radius is initially set to 1, and during a BricsCAD session its default value becomes the previously entered base value.
IMPORT/EXPORT:
IMPORT/EXPORT: following 3D import/export formats are available through a separate module, BricsCAD Communicator.
Export
Import
PASTECLIP FROM EXCEL: an excel spreadsheet, or a range of rows and columns, can now be pasted as a dwg table entity, instead of as an OLE object. The TABLE command now also allows to create a table from XMLSS files.
MLEADER
MSLTSCALE system variable:
PEDITEXT command edits vertices and segments of polylines.
PNG PREVIEW: added support for .png drawing previews, which allow to store high resolution previews with minimal .dwg file size increase.
PRINTER CALIBRATION: printer configuration was extended with the possibility to scale print output so it exactly matches intended dimensions.
PROPERTIES BAR: when no entities are selected, the properties of the current view are displayed - this also allows to modify the view settings.
QUAD cursor menu has been redesigned from scratch
RASTER IMAGES
SELECTSIMILAR command selects all entities of the same type as the current selection, based on a set of matching properties, stored in the SELECTSIMILARMODE system variable. The Settings option of the SELECTSIMILAR command brings up a dialog that allows to define the SELECTSIMILARMODE in a user-friendly way.
SELECTSIMILARMODE system variable sets the selection criteria for the SELECTSIMILAR command. It is a bitcode value holding the sum of following values:
SHEET METAL DESIGN:
SNAPPING
SWEEP command extrudes a closed profile along an arbitrary curve with control over banking during the sweep. If the sweep profile(s) are intersected by the sweep path, the intersection point is used as the base point for sweeping. If profile and path do not intersect, the profile centroid is used as the base point.
LAYCUR command: sets the layer of a selected entity current.
CAMERA command: creates perspective views.
STL (Stereolithography):
IME: implemented inline IME (Input Method Editor) editing for the MText editor.
Workspaces:
