Dimensions angles.
command bar: dimangular
alias: dan, dimang
menu bar: Dimension | Angular
toolbar: Dimensions | ![]()
: dimangular
Select line, arc, or circle <Press ENTER to specify angle>: (Select a line, arc or circle; or press Enter to specify the angle vertex.)
Vertex of angle: (Choose the vertex point.)
First side of angle: (Choose the starting point of the angle.)
Other side of angle: (Choose the ending point of the angle.)
Angle/Text/<Location of dimension arc>: (Locate the dimension arc, or enter an option.)
Dimension text = \A1;142%%d
Angular dimension between two lines
or a pair of polyline segments
Angular dimension of an arc
Angular dimension of two points on a circle
Specifies the angular dimension by three points: |
First point is the vertex of the angle. |
Second point is one leg of the angle. |
Third point is the second leg of the angle. |
Locates the position of the dimension arc. |
Specifies the angle of the dimension text. |
Specifies the text, if different from the default text generated by BricsCAD. |
Choose the entity to dimension -- line, polyline segment, arc, or circle: Line or polyline - you are prompted, "Other line for angular dimension." Circle - you are prompted, "Other side of angle." Arc - you are not prompted; BricsCAD goes immediately to 'Angle/Text/<Location of dimension arc>:' prompt. |
Choose a second line; the angular dimension is drawn between the two lines. |
Other Side of Angle |
Pick a second point on the circle; the angular dimension is drawn between the two points. |
Procedures
To dimension an angle between two lines
To dimension an angle encompassed by an arc
To create an angular dimension defined by a vertex and two endpoints
Grips Editing
Angular dimensions can be edited directly through grips:
Select the angular dimension. Notice the grips.
Drag the grip on the text to relocate it.
Drag the grip on the dimension arc to move it.
Drag either grip on extension lines to move and stretch the dimension.
Drag the grip at the vertex to move it.
DimArc - Places arc length dimensions.
AiDimFlipArrow - flips individual arrows of a dimension.
AiDimPrec - changes the displayed precision of existing dimensions.
