Changes the wording and angle of dimension text; changes the angle of extension lines.
command bar: dimedit
aliases: ded, dimed
menu bar: Dimension | Make Oblique
toolbar: Dimensions | ![]()
: dimedit
Edit dimension [Edit/Oblique/Rotate/REstore] <REstore text>: (Enter an option, or press Enter to restore the dimension text to its default position.)
Left: Original dimension text; right: Dimension text edited with the Edit Text option.
Left: Original extension lines; right: Extension lines set to an angle with the Oblique Lines option.
Left: Dimension text at original angle; right: Dimension text rotated with the Rotate Text option.
Changes the text; prompts you: New dimension text <> - specify the new text; the <> symbol indicate the default text so that you can insert text in front or behind the default, such as "Adjust to <> inches." Selection dimensions to replace with new text - choose one or more dimensions; prompt repeats until you press Enter. |
Rotates (obliques or slants) the extension lines; useful for creating isometric dimensions. Prompts you: Select linear dimensions to make oblique - choose one or more linear dimensions; prompt repeats until you press Enter. Enter obliquing angle - specify the angle. The angle is measured counter clockwise from the positive x-axis. |
Rotates dimension text; prompts you: Angle of dimension text - specifies the angle. The angle is measured counter clockwise from the positive x-axis. Select entities to rotate text - choose one or more dimensions; prompt repeats until you press Enter. |
Restores the text to its original position; this option does not restore edited text or obliqued extension lines. Prompts you: Select dimensions to restore text to default position - choose one or more dimensions; prompt repeats until you press Enter. |
Procedures
Using grips to edit a linear dimension
To reposition the dimension text
To make the extension lines oblique
AiDimFlipArrow - flips individual arrows of a dimension.
AiDimPrec - Changes the displayed precision of existing dimensions.
