Places linear dimensions horizontally, vertically, or rotated.
command bar: dimlinear
aliases: dimlin, dli, dimhorizontal, dimrotated, dimvertical
menu bar: Dimension | Linear
toolbar: Dimensions | ![]()
: dimlinear
Origin of first extension line <Select entity>: (Pick a point; or press Enter to dimension an entity.)
Origin of second extension line: (Pick a point.)
[Angle/Text/Horizontal/Vertical/Rotated]: (Position the dimension line, or enter an option.)
Dimension text = xx.xx
Dimensions an entity. Prompts you: Select entity to dimension - Select a line, polyline segment, arc or circle to dimension; other entities cannot be dimensioned with this option. [Angle/Text/Horizontal/Vertical/Rotated] - Position the dimension line or choose an option.
Specifies the angle of the text; useful for keeping text horizontal with inclined dimension lines. Prompts you: Angle of dimension text - specify the rotation angle of the text. |
Specifies the text; useful for overriding the default measurement generated by BricsCAD. Prompts you: Dimension text - specifies the replacement text. |
Forces the dimension to be horizontal. prompts you: Location of dimension line [Angle/Text] - Position the dimension line or choose an option. |
Forces the dimension to be vertical. prompts you: Location of dimension line [Angle/Text] - Position the dimension line or choose an option. |
Rotates the dimension by a specified angle. Prompts you: Angle of dimension line <0.0> - specify the angle of the dimension line. |
Procedures
To create a horizontal or vertical linear dimension
To create an aligned linear dimension
To create a rotated linear dimension
Grips Editing
Linear dimensions can be edited directly through grips:
Select the linear dimension. Notice the grips.
Drag either grip on the dimension line to move the dimension line; the extension lines change length.
Drag the grip on the text to relocate it; the dimension line moves along, and a leader line is added, if required.
Drag either grip on the extension lines to move the extension line; the dimension line changes length.
DimArc - Places arc length dimensions.
AiDimFlipArrow - flips individual arrows of a dimension.
AiDimPrec - changes the displayed precision of existing dimensions.
