Dimensions the radii of arcs and circles.
command bar: dimradius
alias: dimrad, dra
menu bar: Dimension | Radius
toolbar: Dimensions | ![]()
: dimradius
Select arc or circle to dimension: (Choose an arc, polyline arc, or circle.)
Dimension text = xx.xx
Location of dimension line [Angle/Text]:: (Position the dimension, or enter an option.)
A circle with radius dimension placed outside
An arc with radius dimension placed inside
Specifies the angle of the text. Prompts you: Angle of dimension text - specify the rotation angle of the text. |
Specifies the text; useful for overriding the default measurement generated by BricsCAD. Prompts you: Dimension text - specifies the replacement text. |
Procedures
Creating center marks or center lines
To create a diametrical dimension
Grips Editing
Radial dimensions can be edited directly through grips:
Select the radius dimension. Notice the grips.
Drag the grip on the circle to rotate the leader and text around the circle.
Drag the grip on the leader to relocate it and the associated text.
Drag the grip at the center of the circle to relocate the dimension anywhere in the drawing.
DimArc - Places arc length dimensions.
AiDimFlipArrow - flips individual arrows of a dimension.
AiDimPrec - changes the displayed precision of existing dimensions.
