To launch an X-Solid command you can either click the tool buttons on the X-Solid toolbars, choose the commands in the X-Solids menus or key-in the command in the command bar. The XDIA command can suppress X-Solids command dialogs and thus force command-line interpretation .
Icon |
Tool name |
Keyboard |
Polar array |
Creates a polar array of solids by copying and rotating a selected solid about an axis. |
Rectangular array |
Creates an array of solids by copying a selected solid in a rectangular pattern. |
Box |
Creates a three-dimensional solid box. |
Chamfer |
xchamfer |
Bevels edges of a solid. |
Cone |
Creates a three-dimensional solid cone. |
Solids command center |
xcsolids |
Accesses the most-commonly used X-Solids solid creation and modification functions. |
UCS command center |
xcucs |
Accesses the X-Solids UCS capabilities, to pick, define or recall UCS settings. |
Cut |
Cuts 3D solids using 2D profiles as cutting tools. |
View command center |
xcview |
Accesses the X-Solids View capabilities, to pick, define or recall View and Viewport settings. |
Cylinder |
Creates a three-dimensional solid cylinder. |
Dialog |
xdia |
Suppresses X-Solids command dialogs and thus force command-line interpretation |
Explode |
xexplode |
Breaks a solid down into face or wireframe entities. |
Extract |
xextract |
Extracts a copy of a face or edge of a solid, or an edge of a region as a separate entity. |
Extrude |
Creates a three-dimensional solid by extruding 2D objects. |
Fillet |
xfillet |
Rounds edges of a solid. |
Intersect |
Creates a solid by intersecting two or more solids. |
List |
xlist |
Displays the CSG tree of selected X-Solids solids, in one of two textual formats. |
Offset |
xoffset |
Creates a new solid by offsetting all faces of an existing solid at a user-specified distance. |
Punch |
Punches holes in 3D solids using 2D profiles as punching tools. |
Purge |
xpurge |
Removes the editing data (the "history" or "CSG" data) from selected solids. |
Quickdraw |
xquickdraw |
Instantly creates 2D geometry from selected solids for the completion of multi-view orthographic and isometric drawings. |
Retract |
xretract |
Separates a solid by undoing the most recent Boolean operation that was applied to the solid. |
Retract all |
xretractall |
Explodes a composite solid into its component primitives. |
Revolve |
Creates a three-dimensional solid by revolving 2D entities. |
Section |
xsection |
Invokes the Bricscad SECTION command, which creates a 2D region of the cross section of a solid through a user-specified plane. |
Shell |
xshell |
Subtracts the interior from an existing solid to create a thin-walled solid. |
Slice |
Slices solids with a plane. |
Edit solid |
xsolidedit |
Edits all X-Solids solids: primitives, composites, primitive components of composites and solid arrays. |
Sphere |
Creates a three-dimensional solid sphere. |
Subtract |
Creates a solid by subtracting one or more solids from one or more solids. |
Sweep |
Creates a three-dimensional solid by extruding 2D entities along a path. |
Torus |
Creates a three-dimensional solid torus. |
Trim |
Trims 3D solids using 2D profiles as trimming tools. |
UCS |
xucs |
Defines a new UCS or restores a saved UCS. |
Previous UCS |
xucs + p |
Restores the previous UCS in the list of UCS's used in the current session. |
Next UCS |
xucs + n |
Restores the next UCS in the list of UCS's used in the current session. |
Union |
Creates a solid by joining two or more solids. |
Restore View |
xviews |
Gives command-line access to the Next and Previous entries in the list of views used in the current session. |
Previous view |
xviews + p |
Restores the previous view in the list of views used in the current session. |
Next view |
xviews + n |
Restores the next view in the list of views used in the current session. |
Wedge |
Creates a three-dimensional solid wedge. |
© Menhirs NV. All rights reserved. |
